What car tire size should I fit - 225/60 or 215/60R15?
OzarkBob
Hi everyone, I am a fairly new Spyder rider, bought my 2021 RT Limited last fall. This is my first post. I have about 8,700 miles on the Spyder now and am looking for a new rear tire. After reading extensively on this forum about using a car tire, brands, sizes and air pressures I have narrowed it down to the General Altimax RT43. My questions is about what size. I had originally decided on a 225/60R15 because it was closest to the OEM tire size, 225/55R15, but I see a lot of people using the 215/60R15. I like the idea of the 225/60/R15 because of the extra width but is there a reason I should go with the 215/60R15? We ride 2 up 90% of the time.
We are really enjoying the new ride and appreciate all the information here on the forum.
Bob
Bob
Hi Bob, welcome to posting on the Forum! :thumbup:
There's arguments either way on which tire width to go for, either will bring your Spyder's speedo (& odo too! ;) ) a little closer to 'accurate', but I'd say the biggest/most valuable of the reasons for going for the 215/60R15 over the 225/60 is that the Spyder is somewhat 'over-tired' with the 225, especially if you don't drop your car tire pressure to 18-ish psi, and it's easier to run into hydroplaning problems with the wider tire if you ever end up riding in the wet. :rolleyes: . Sure, you can reduce the likelihood of that by reducing the pressure a bit more, down to about 16 psi, but if it starts raining while you're out on a ride, who wants to stop to drop rear tire pressures, even if riding on might be a bit more iffy?!? :dontknow:
Other things may come into play/be of concern too, but without going thru a few of them some in detail, the simple fact is that the 215/60R15 is usually a 'better choice' of a/mkt tire size for the majority of Spyders & Spyder riders, including those who ride heavily laden &/or 2-up most of the time. :thumbup: . But it is your Spyder, and if you prefer the 225/60 for any reason, maybe just like the fat rear tire look more, &/or don't ride in the rain too often (altho maybe that one does mean you should go with the narrower tire to be safer if/when it does rain?!? :dontknow: ) then you should run the tire size/width you prefer - both those sizes will fit! :ohyea:
Good Luck! :cheers:
Bob
225/55-15 rear OEM tire ..... Nope ... it's a 225 .... 50 -15 , and you want to go to 60 ..... I think that size ( on a 260 width ) ... very well may cause fitment issues .... the 215/60-15 is already a much larger tire ( in circumfernce ) than the 225/50-15 .... going even larger 225/60-15 imho is asking for trouble ..... good luck .... Mike :thumbup:
225/55-15 rear OEM tire ..... Nope ... it's a 225 .... 50 -15 , and you want to go to 60 ..... I think that size ( on a 255 width ) ... very well may cause fitment issues .... the 215/60-15 is already a much larger tire ( in circumfernce ) than the 225/50-15 .... going even larger 225/60-15 imho is asking for trouble ..... good luck .... Mike :thumbup:
Thanks BlueKnight911 for catching my mistake:banghead: Now I understand why the 215/60R15 is the better choice. I'll be ordering one tomorrow.
I appreciate both your's and Peter's advice. Bob
I hope your read this post BEFORE you buy a REAR tire ..... I don't type well so just look for my NEW thread about a NEW Rear tire I just found...... Mike :thumbup:
Thanks Mike. I will look for at. I haven't quite figured out how to navigate around the web site. LOL I have trouble finding the thread I posted in...Bob
Mike, which this post were you referring to, What's your latest tire recommendations again?
There's NOW a LINK to the thread .... see POST #5 above it's in RED ..... and much thanks to Peter who added it to my POST :clap::clap:... makes life easier for those computer challenged folks like me ::thumbup:......Mike :2excited:
I have the General 215/60R-15 and it really is perfect. NO fitment problems and the speedo is right on. The 60% aspect ratio gives the correct diameter to make the speedo very accurate. The 215 width is just fine for 2 up riding, which I do a fair amount ( at about 19 to 20 PSI).
Learn from Mike and Peter----------------
Lew L
Ok.. my head is swimming with all these tire numbers, year model of Spyder, how much load the Spyder carries..and their associated reasonings.. I have read them all and made handwritten notes. I look back at my notes and find various sizes written down and just throw my hands in the air as it is so confusing to me. I know NOTHING about tires except inflation numbers and I want good tires all the way around that hopefully last a long time. Looking for grip on slick bumpy areas in a curve.
PLEASE could someone tell me which tires to specifically buy for both front and rear for MY Ride?
Thank you, thank you gentlemen.
Here are the facts for my ride:
2021 RTL Spyder
7144 miles
Total load with driver and stuff in storage areas: 145 lbs
One-up…. 99% of the time… occasionally 2-up once or twice a year
Twisty hill country paved/often-bumpy-in-the-curves, side roads, and cattle guards
Those roads will have a 20-35mph sign but we usually take them at 10mph+/- over the sign.
Interstate highways 70+mph
Usually dry weather unless caught out in a rain.
Current OEM Front: Kenda KR31 165/55R15. Run them at 18 cold
Current OEM Rear: Kenda KR21A 225/50R15. Run it at 28 cold
2021 RTL Spyder
7144 miles
Read my post # 5. & #10 above .... But be advised these are AUTO tires and not all dealers will mount them .... there are other ways to get it mounted tho ..... Mike :thumbup:
Read my post # 5. & #10 above .... But be advised these are AUTO tires and not all dealers will mounty .... there are other ways to get it mounted tho ..... Mike :thumbup:
Thank you for reply Mike. Believe me I have read your posts.. and did so again just now.
Will the size you discussed in those posts fit my 2021 Spyder RTL.. since I know the tires you ordered were to fit your 2014 Spyder..?
I have no idea if the 2021 and the 2014 take the same tire size.
Thank you for your patience with this clueless person.
Lew L
So a 60R is not causing any fitment issues. Then post #3 is incorrect.
Lew L
The post you quoted Ex is referring to running a 215/60, while post #3 is expressing an opinion and a word of caution about running running a 225/60 tire - see below... ;)
So no, post #3 is fine as it stands. :thumbup:
Aspect ratio is a % of the tire width and it is the side wall height. 60% of 225 mm is 135 side wall height. 60% of 215 is 129 mm. A slight difference in diameter. Again the 215/60/ 15 is a good fit.......
The wheels and tires of the 14 and 21 are the exact same size ( not the same appearance tho )..... Most folks use 215/60-15 on the rear because it is both available and corrects the speedo / odometer error from the OEM size .... Mike :thumbup:
In post #3.- I was referencing the OP thinking a .... 225/ 60 -15 would fit .... I don't think it will, there is very little room at the REAR of the tire..... Mike :thumbup:
Thank you ever so much!
Also.. I appreciate the tip you gave a few months back about placing a wedge on the Utopia backrest to get just the right angle for lumbar support.. prior to that simple tip I had tried some harsh attempts at getting a supportive angle on the backrest..
