Pennyrick
Went to start the RT this morning and all I got was a 'Chug' from the starting motor as the battery obviously didn't have enough juice to turn it more than once.
As I hooked up the trickle charger I began to run through my mind what may have caused the drain as it ran fine when I pulled it into the garage the night before.
Then I recalled the problem I had at Pet Smart. We were almost out of dog food and my wife asked me to pick up a bag. I bought a 40 pound bag and thought I could wiggle it into the frunk on my RT. I managed to get the bag in but enough of it stuck out that I could not secure the lid of the frunk. I pulled it out and bungeed it on the passenger seat and rode home.
After hooking up the charger I tried to release the frunk lid with the electric switch and it would not open. I knew there was enough juice left in the system to trigger that switch so something else was going on.
I opened it manually and found the rubber gasket was off all around and had become twisted (likely happened when I pulled out the dog food and closed the lid the night before). I put the gasket in its proper place and closed up the frunk.
Once the battery was fully charged this afternoon, I checked the frunk switch and it released with no problem. Took the Spyder on a run and everything runs okay.
My thought is that somehow the switch stayed engaged overnight due to my messing with the frunk lid and that flattened the battery.
Does that make sense or does anyone have any other suggestions?
