What does the cotter pin on the rear axle do?
Eckhard
It doesn't stop from the nut coming loose. One would need a Castellated(Castle) nut for that.
Does it stop the the axle from sliding out?
Does it stop from losing the nut as well?
I would have thought if the nut came loose one would notice when riding? Does anyone have any experience here?
Eckhard
As you are technically correct, a castle nut will stop the nut from loosing to much from the torque spec.
But the cotter pin will still stop a nut from loosing past the pin regardless, as it may go past the torque spec, the pin is still going to stop it.
Id image after a long long long period of time, the pin will probably wear away enough for it to snap/disintegrate for the nut to completely fall off & thus the axle possibly coming out.
Does it stop the axle from sliding out?
Yes
Yes
I wouldn't bet on it. Been riding and wrenching for a lot of years and nothing I see or hear will surprise me anymore. You would think two people riding a fully loaded Goldwing would know they only have 15 lbs. of pressure in their tires, BUT THEY DON'T. You would think some riders would know the brake pads are shot and have been cutting into the discs for the last thousand miles or more, BUT THEY DON'T. I could go on for an hour. Personally I would like to see the castle nut set up, but I will take what we have. It only works if you keep a pin in though. I have seen many bikes where it was just left out.
I must have been lucky... I removed it when I put my hitch on and would leave it off when the hitch was off for over 4 years and never noticed a difference.
The cotter pin is pretty much a CYA to prevent disaster if the axle nut should come lose. Properly installed there is no need for the cotter pin.
Just about every nut on an aircraft has a wire twist lock on it so things don't go bad at 100 MPH at 10,000 ft. A cotter pin in an axle nut serves the same function so nothing goes bad at 60 MPH at 4 ft. If things were to go bad in either situation the results could be the same.
Axle's without cotter pins is a big fat NO for me.
I do not advocate NOT using the cotter pin. Just saying that it would have to be be a pretty negligent install to ever actually need the cotter pin. The pin is a fail safe for an un-tightened axle nut than for anything else. I put mine back in and I did the work myself.
No axle cotter pin on mine. I have a hitch and the hitch bolt has a cotter pin. I don't think the hitch would fit if there were a cotter pin in the axle.
Sorry, but that is not correct. In aviation / aerospace many fasteners are simply locknuts with no safety at all. However on modern aircraft, flight controls have double safeties, such as self locking castle nuts that are cotter keyed.
As for safety wire, yes, still used, but not often on newer aircraft, plus with the new style cable safty setup, that is becoming more common.
That has been my experience when I was involved in building aircraft. (737s and 747s) But that was more than a few years ago..... I understand that today they use more composites and glues..... Jim
True, but the hitch also captures the axel nut so it cannot come off. The cotter pin on the hitch bolt prevents the hitch bolt from sliding out.
I ditched the cotter pin, now use a safety pin. No tools needed.
As for why they use a cotter pin and no castle nut. Maybe there is some regulation regarding it must be saftied to prevent the axle from coming out. Granted it may loosen in theory, but could never fall out.
Yes, people are sometimes dumb and oblivious to what goes on around them. It happens.
Not the same application but same principle, but I drilled a hole and use a cotter pin on the stud of my hitch ball. I decided I better do that after I found the hitch ball nut had worked loose and was close to coming off. That was while I was pulling my trailer on the Interstate!
Your choice....
It does what it was designed to do. But, I would not want to be the guy who did not put it in and an accident occurs that it would have prevented....:lecturef_smilie:
The reason they do not use a castle nut is for simplified engineering. If they used a castle nut, it would be so tall that the BRP hitch would not fit and you would not be able to install the cotter pin in the BRP hitch. BRP wants to sell you the hitch and hopefully an overpriced trailer, and keep the design simple. A low profile axle nut makes the design and installation of the hitch much easier and simplified. It does this and is still able to provide a safety factor to prevent the rear axle from falling out if the nut comes loose.
Maybe, but more likely they use a plain nut to save time and cost. Castle nuts cost more to purchase. Add in tnat during assembly, they simply tighten the axle to specs then slip in the cotter key. No alignment of the nut to the axles drilled hole. Simple, fast and low cost.
If the plain nut was installed to facilitate a hitch as the primary reason behind using the plain nut, most likely Can Am would supply the nut in the hitch kit. Besides, when the hitch is installed, you can no longer safety the axle as you do without the hitch. The long hitch bolt passes through the axles length, that bolt does have a castle nut and is saftied.
