What GPS are you using?
Wow, Racoon, that is a very clever, unobtrusive security lock that you got from Lamont. Much better than the other bulky ones I’ve seen. :clap:
Personally, since popping the XT out of the cradle is so easy with its single press, I simply put it in my jacket pocket, or in my helmet that I lock in the saddlebag if I’m leaving my jacket behind. But that’s just me. ;)
It is easy to pop out after removing the locking pin. It has a "key" you use to remove the pin, which is attached to my keychain.
If I'm only going to be parked for a few minutes I'll leave the gps in place.
If I'm parked for longer than a few minutes I'll take the GPS off and lock it in the top case.
I use my phone but use different apps depending on what I am doing.
I use Waze for highway driving for the crowdsourcing reports.
I use Rever pro for planned routes on back roads plus it has a radar overlay so you can see when you are coming up on rain that is on your route.
I use google maps for loss of signal, sounds weird but I have downloaded all of my nearby states to its cache so it is available offline.
My point was that if you get in the habit of pressing the button, removing the XT, and dropping it into your pocket (or trunk) when you leave the Spyder, you will never have to buy, or fiddle with, any kind of security lock... or worry about some clown breaking something trying to steal it. There is no benefit leaving it in situ when you shut off the Spyder, as it powers down anyway. ;)
Pete
I had no concerns leaving my Zumo XT attached overnight with my Touratech lock mount and keyed RAM ARM.
I have a TomTom 550(?) made for motorcycle riders. I rarely use it. I know it allows you to "plan" routes with stops you want. But I really just wanted familiarity because I have a TomTom in the truck. I upgraded the old one in the truck last year to a newer TomTom as well to stay in the family. Still a learning curve. I still carry maps though.
Pete
I do understand your point, and I am comfortable with the way I'm using it. :)
I also use the Moto Pumps security lock for my XT. I have the LaMonster bracket and have left the XT mounted when I am away from my F3. I wear a doo rag head cover, so when I get off the spyder, I take it off and put it over the XT. Out of sight out of mind. Less prying eyes and fingers.
Gee Racoon, I’m not trying to tell you how to live your life:dontknow: ….. I am simply offering an alternative to those who are considering buying some kind of locking device for their XT.;)
Pete
So I got a picture of the set up I think I'm going to use. The GPS is center and Sirrius is left. The "sun shades" are index card boxs with the smaller lid side cut off and mounted thru to the mounts to the units.
I just use my phone and android auto.
I was really wondering why this wasn't the norm. Why use a dedicated GPS today that has to be updated has limited function when compared to a phone? Not to mention it's just another thing that has to be plugged in and looked after when traveling. :dontknow:
It wasn't until a couple of years ago that I started paying for a data plan on my smart phone.
Before that, I used my phone to make calls and occasionally to play a few simple games on.
I did no web surfing or emailing or anything else that used data, since I had to pay for all of my data.
I also did not use SMS text messaging, either.
:::shrug:::
Main benefits of a GPS vs Cell Phone:
A GPS eliminates the need for a cell signal (I know, you can probably download a map ahead of time, but if you need to change on the fly in the middle of nowhere, well...)
A GPS can sit in a massive downpour and work without issue.
A GPS is designed to sit in direct sunlight and potentially get hot without issue.
Often, a GPS has a larger screen that is easier to manipulate with gloves.
I guess it depend on where and how far you are going. :dontknow:
I'm not a long distance traveler so none of those issue are relevant to my situation. Thanks for pointing out the benefits. If i ever take the plunge and decide to travel I will need to consider a GPS.
:cheers:
:cheers:
If you never leave a city or get out in the country, a cell phone is fine.
I don't understand why people feel a need to deride others' choices when their reality does not match the question.
Paper maps. Those GPS things always either get me lost or way out of my way.
