What is the proper way to connect multiple blue tooth devices without issues.
USAF
Hey guys, I have my phone and my headset communication devices connected to my 22 RTL. The phone is used for XM radio play and Sena SMH10 for talking to my wife. I tried making a call while pulled over and things got all messed up after that, I had to restart the phone and head set to get things back to normal. I have them both currently connected to the Spyder and not to each other. Is this how they should be ? As it is set up, I could not hear anything on the phone call in the headset or the speakers of the Spyder.
I have my phone paired to my headset and the headset is paired to the bike. I always let my phone and headset pair before starting my spyder, no problems for me that way.
Now is this the proper way? :dontknow:
BRP connect is a ton of fun
I connected my phone and headset to the bike as you have - they both work for me to answer / talk on the phone and listen to music either thru the speakers or headset. I did encounter a problem when trying to talk to another user headset to headset so I had to reconnect my phone to the headset to get some group changes made then disconnected it.
There are a couple of threads I followed to gain insight from others which might help you also.
https://www.spyderlovers.com/forums/showthread.php?152338-BRP-GO-Connect-amp-my-helmet-communicator
https://www.spyderlovers.com/forums/showthread.php?153065-How-should-I-connect-Sena-to-BRP-Go
