What Mpg are you getting at normal speed limits?
moses
can anyone tell me the approximate gas mileage they are getting riding at normal speed limits.
Thanks
Thanks
Don’t know what model you’re referring to, or whether a Spyder or a Ryker, or an Imperial Gal. or U.S gal., but I’m getting 45++ on my RTS (Imp. Gal).
Do a search for MPG on this forum and you'll read comments until your eyes are bleary! I've characterized Spyder MPG like a kid jumping up and down on a trampoline it varies so much! Sometimes I think it depends on if the sun is shining or not! Somewhere in the 30's is most commonly reported.
Spyder RTL 2016
:chat:...I get between 33 to 39 mpg on my Spyder.
Speed is the biggest factor.
So 55 mph in 6th gear @ 39 mpg.
At 70 mph in 6th gear @ 33 mpg.
I can live with those numbers. ......:thumbup:
Enjoy your Ryde Time.
34 mpg for my 2015 RT. I have done a bit better and a bit worse, but 34 is the number I see most of the time. When traveling I avoid big cities and freeways like the plague so that is two lane travel with as many twistie parts as I can find.
Same with my 2014 RTL
2019 Spyder F3S (89t rear pulley)
Normal putzing around: 36-40 mpg
Fully loaded up with (3) pieces luggage at interstate 80mph: 28-30 mpg
Even with the ECU flash, I'm around 37 to 39 with my beautiful bride in the back. Higher speeds = lower milage.
Lew L
not that anybody really cares but the old VTwin is a consistent 27. something. Since it is always point something I have to assume that I am having occasional bouts of 28 or 29 or:yikes:30. It must be my fat *** that weighs it down.
I am one of those that keeps track quite often on mileage.
We drive a lot of miles a year now. Most of those miles are on secondary roads. Most are driven about 40 - 45 miles per hour. Currently have two 1330's. (F3L). Also had a 1330 RT-S. (2014). My experience has been high 30's to low 40's. 38 - 41. If we get on the road at highway speeds 55, 65, then the mileage will go down a couple miles per gallon. We do not pull a trailer or ride two up. Both of those situations will reduce the mileage.
Our experience with the 998's. Have had four...two RS/GS and two RT's. Our mileage on these was always low 30's.
:bowdown:
I have kept track of my fuel consumption, and have averaged 47 imperial miles per gallon. I have 4,500 miles on my F3. No trailer and no passenger.
MPG's
I have a 2014 basic RT ..... normally I have " ECO " mode on and avg. in the 38 to 40 mpg range .....( using 87 w/ ethyl ) UNLESS I'm in the " Twistee's ", then all bets are off :yikes::roflblack::roflblack::roflblack:..... Mike :thumbup:
As per my post above, that’s identical to my RTS with 37,000 miles on it...solo riding, no trailer.
I have a 2021 RT. Even when riding without a passenger, and in Eco Mode, I seem to average around 34 mpg. But I do tend to rider faster than the posted speed limits. I always fill up before I each 200 miles.
