What size auto tires is everyone running?
CJ.RamMan
I have read several threads regarding tires and many of you are running car tires. I see a lot of people throwing out the brands they are running but not the sizes they are running. I have also noticed it is no secret that the 165/55r15 size is very limited across the brands. I have found a few more choices at the 165/60r15 size and again a couple more at 165/65r15. In addition to being curious what others are using I am also curious about the point in which the Spyder VSS will notice the revolution difference between the rear and the front tires if the standard 225/50r15 is used on the rear but a larger diameter on the front. Using a tire comparison calculator I am showing a difference of 26 revolutions per mile between the 165/55 and the 165/60 front tires. Has anyone experienced any issue, or is everyone also compensating with a different size rear tire?
Also does anyone have size and brand suggestions for the 14 inch Spyder rims? My GF's Spyder has the smaller rims mounted.
Uh oh, here we go again.....
My Bookmarks section under Spyder has 35 bookmarks on tires alone. There are literally dozens of threads about car tires (and tire pressures), many of which deteriorate into bickering among those that know and those that think they know. I suggest you search a little more, make your own determination about who the Forum experts on tires are (it will become clear as you read the posts) and consider their advice.
NO tire pressure questions!!!!!!
Please don't ask about tire pressure !!!!!!! Two other threads have gotten a bit nasty and should be removed.
Regarding tire size
Here is how I found the correct size auto tires for my Spyder
First get some string or twine, jack up the front tire left or right
wrap the string around your tire and mark the string with a black sharpie
the black mark should be at the point where the string wrapped around the tire
meets the end of the string.
lay it out on a table and with a measuring tape measure the length.
now measure the width of the tread and the width of the cross section the easy way
to do that is to get 2 4X4 about 40 in. long if you don't have 2 squares put one on each side
and touching the sidewall of the inside and outside of the tire, measure the distance between
them. Armed with those measurements go to the tire store and start measuring tires
till you find the size that closest matches what you have, that is all there is to it....
Now go out and find your car tires
Ride Save
Dave
I didn't ask anything about pressure. I asked about size considering most manufacturers do not offer tires in the size 165/55r15. I see people talk about their Yokohama, Kumho, Federal, etc I am asking the SIZE of the tires. I have read enough about tire pressure I have my own opinion of what I wish to try when I do get a set of car tires for my Spyder.
Is everyone so afraid of tires they cannot say "hey CJ I'm running a 165/60r15" or whatever it is you have on your Spyder? I don't need twine to figure the diameter. I also asked if slight variances in diameter affect the Spyder's safety systems. Twine won't answer that question either. I'm not looking to start a p*ssing contest, just asking what size tires you guys are running
I'm not at home and can't remember, but tomorrow I will be more than happy to tell you what is on my 2015 RT. I do have Federals on front and General on the rear.
TIRE SIZE
IMHO , the Vredestein Quatrac 5 is the best performing tire sold to day ..... and because they cater to the European market ( heavily ) they have the best selection of tires ....IN SIZES TO FIT OUR SPYDERS ....visit TireRack OR Vulcan tire .... I think Simple tire still markets them also ....... Mike :thumbup:
Thank you for the reply. I searched the Vulcan tire site but cannot locate a 165/55r15. Does a slightly larger diameter affect the VSS system? I did not know how much "play" they build into the system. Didn't want the system to think I am constantly losing traction.
Tirre Sizes
I am running the General Altimax RT 43 ( size: 215/60 R15) on the rear.
And on the fronts I am running Continental Contiprocontact ( Size 165/60 R15).
I have a 2014 RTS-SE6 :spyder2:.
Deanna
Deanna
Deanna, are you running that size rear tire to compensate for the larger diameter fronts?
Yes, I am.
The front tires have a fender support, so I have to run the 165/60R15.
If I ran a 170/60R15 (in the front) the screws( fender support screws) would have cut into the tires. That is why I went with the 165/60 R15. I had a can am dealer install them.
Deanna
Yes, I am.
Deanna
What about a 175/55R15???????
Computer recognizes nothing
Really ok 175/55/15 on front 215/60/15 on back computer on my Spyder must be blind vss never engaged I believe your over thinking it😁
I have:
Rear: Yokohama S: 205/ 55R15
Front: Yokohama Avid S34: 175/ 55R15
They have pressurized air in them. :)
On the 2014 RT we are running -
Front = Kuhmo Solus KH16 in 175/55R15 currently has 35,735 miles with 4/32 tread left
Rear = Michelin Premier A in 205/60R15
On our 2015 F3s we are running -
Front = Vredesten Quatrac 5 in 175/55R15
Rear = Yohohama S Drive in 205/55R15
The Kuhmo has provided good tread live, but the Vredesten has handled better. I will be going to them for the RT next.
The Michelin has been outstanding on the RT rear and will stay with them for the RT.
The Yohohama has been great on the F3, but will try a Vredesten next based on how well they handle on the front.
Size has not made a difference as far as the computer on the Spyder
YOUR TIRE SIZE
Yes, I am.
Deanna
Nope 777 your mis-taken ....I bought those tires from you ..... they 175/65-15 General Altimax RT43 and they work great on my 2014 RT with basic fenders that I shimmed with washers .....your welcome ..... Mike :thumbup:
tires size difference
To the best on my recollection this has not occurred with any Spyders ....... Yes the BRP system can detect the difference - however the Spyders are very, very limited in what sizes are available so a mis-match large enough to triiger a code isn't possible IMHO ..... Mike :thumbup:
I've written this on several other tire threads. If you go with wider tires, just snip off the excess 1/4 inch fender bolt length and you will not have a problem. No need to try to shim the fenders. Easy fix
