36MM for the cap and three fingers for the filter :roflblack::roflblack::roflblack::roflblack::roflblack::roflblack::roflblack:........or tongs if you want to stay clean .......... Mike :thumbup:What size tool do I need to remove the oil filter on my 2017 RT. Not the plug but the filter itself.
If you are going to use a socket I'd recommend a 6 sided socket. I found a 36mm wrench at Summit Racing for a very reasonable price, including shipping. I use the wrench for both the filter and rear axle.
Don't bet on it! I think you would readily convert the hex shape of the thin metal of the shower tool to round shape at 160 ft-lbs. At least I wouldn't try it! I don't think you could get 160 ft-lbs torque on the shower tool without totally distorting the screw driver holes for turning it.No doubt the plumbing tools can handle 160ftlb of torque.
This is what I got to take off the filter and rear axle nut, built very stout.
https://www.amazon.com/Pit-Posse-PP...+wrench&qid=1552437890&s=gateway&sr=8-1-fkmr1
This is the one have: https://www.amazon.com/OTC-4882-Rea...s=gateway&sprefix=36+mm+axle+nut+tool,aps,240This is what I got to take off the filter and rear axle nut, built very stout.
It's a heavy wall tube. The spec is 166 lb-ft torque beginning in 2013. It was 96 lb-ft before that. The axle and nut part numbers changed in 2013 so BRP most likely changed the strength of the steel. I saw a discussion here of axle nuts coming loose in the early models of the Spyder. A solid bolt of the same size normally would be torqued to about 200 lb-ft minimum. One chart I came across shows torque values up to 500 to 800 lb-ft for 1" bolts, depending on the grade of the steel. So, 166 is lower than the usual real world number.It's been discussed here before, but you may want to re-think that 160 ft-lb. of torque on the rear axel nut. Correct me if I'm wrong, but I believe the rear axle is tube, not a shaft.
Adjustable wrench or a channel lock with a rag on the plug cap...whole lot cheaper than buyin' a special socket that gets used a couple times a year. And no, it won't damage anything if used correctly.....don't want anyone here gettin' their britches in a bundle by me sayin use a channel lock
That will not work for the axel, but for those that never touch their axel then it will work for them. Since I do the price of a good 36mm socket is worth it.
