Arion
Bicycle tires?  Not sure I understand that comment.  Regardless, there are lots of posts regarding tire pressures, depending on whether the tires are OEM or car tires that you can review.  However, you should, at least as a starting point, accept the manufacturer's recommended pressures. Different tire profiles and different sidewall construction than those on your Kawasaki account, at least in part, for pressure differences.   Not to mention weight being carried by three wheels rather than two.
BRP would be in a legal bind if they recommended tire pressures that weren't safe for their thousands and thousands of customers. MY Spyder wears Vrederstein auto tires on the front and the OEM tire on the rear. Front pressure on mine is 15 - 16 PSI and rear is 26-28 PSI and has proven acceptable over many miles.
