What tire size is best for the Can-Am Spyder RT 2022 model?
I run the 215/65R15 on my RT S2S. Its about 1" taller than the OEM tire, which brings the speed indicated on the dash to within 1/mph of what is indicated on my cell phone GPS. Stock the dash is always 3-4 mph under that which the GPS shows.
the 225/60/15 just installed made the speedometer read exactly what the GPS was saying.
Have you inspected for inner mudguard damage?
Believe others mentioned the gen 3 RT series is having issues with inner mudguard damage with the taller tire contacting the plastic as the rear suspension compresses.
On earlier Spyder, errors in displayed speed can be corrected electronically with BUDS. Our indicated speed error of about 3 mph at highway speeds was adjusted to exactly match the displayed GPS speed. Took longer to verify accuracy of the change, than for me to connect BUDS and make the setting change.
Rear Tire stock 2022 RTL
I am driving a Can-Am Spyder RT 2022.
Currently, a 30mm spacer is installed on the front and a tuned 6J wheel is installed. The front is equipped with Tire size 195/50R15
Rear tire
205/60R15
205/65R15
215/65R15
Can these 3 tires be installed on the Can-Am RT?
225/60R15 Forceum Hena .correct speedo, no clearance issues, milage will be better than stock. no figures yet.m
Front tire is a 195?
Doesn't that kind of mess with the scrub angle and make the steering a little heavy?
Just curious how it changes the feel?
