Thank you. As it is not spoken of in the OM I won't mess with it. I do not want to over inflate it.
You should probably check the pressure in there every now & then - they have been known to 'lose air over time' and will be damaged if you run them for too long empty! They should always have at least about 5psi in there; and unless they've upgraded the bag, shouldn't ever go over about 90-100 psi - it's a tiny bag, so it won't take much to reach those upper limits, but I know from personal experience that unless the bag is already compromised, it'll handle double that max fairly readily - but you
really don't want to ryde on a Spyder with that much air in thecOE spec air bag..... not if you want to keep all your fillings & teeth, and would like your kidneys to remain functioning properly anyway! :shocked: Still, all it really does is set the 'static ride height', and for most, that means something in the 30-40 psi vicinity for solo/unladen ryding; something more for 2-up/loaded ryding. :thumbup:
But I believe the Ltd's still have an '
auto ride height levelling system', the
ACS that's often touted as being one of the major attractions of the Nanny suite (would be too,
IF it worked reliably & wasn't so prone to compressor failures; air bag &/or line leaks; and height sensor control rods coming undone....
) which means that there are fixed 'upper & lower' air pressure limits
AND a pre-set 'static ride height' embedded in the controlling computers somewhere, so if you
ADD more air than those pre-sets recommend; or increase the ride height above (or decrease below) the set height, the moment you start the engine, turn the park brake off, and engage a gear, the auto system will either dump or add more air until your machine & its ACS return to the pre-set parameters!
The 'Nanny' won't let you get away with anything much on this one - it's HER WAY, or NO WAY! :gaah:
So go ahead & check the air pressure every couple of weeks; even add or drop air pressure if you like (preferably using a 'low pressure pump' & not a hi-volume/hi-flow 'shop air' compressor!); it won't take you long to work out what pressure the Nanny wants it to remain at, or if it's working at all; and if it's not working, you can at least get it fixed, or better yet, bypass all the problematic 'auto' stuff & go full manual like many of the rest of us have!
hyea:
Enjoy! :cheers:
