Where is the reverse actuator and can it be replaced at home?
If is on an RT SM5, you look right next to the oil filter and you'll see a cable attached to a soleniod, that is it. There was a recall on a few models. Mine was not one of the serial number's recorded, but it was out and covered under warranty. IMHO, you should be able repair it yourself.
My trailer module blew the fuse and the reverse actuator. My Best warranty covered replacement of the trailer wiring on the Spyder and on the trailer itself along with the reverse actuator. So my response to the OP would be the reverse actuator is located at your dealer!
Reverse actuator 2010 RT
Just wondering what symptoms for a bad actuator? My Rt SM will go into reverse every time but once in awhile my screen will not revert back to temp gauge, it stays in reverse mode. It dies come back after awhile and it only does it on occasion.
Can anyone tell me where the reverse actuator is located and can this be replaced at home?
My local mechanic just fixed mine and from what he told me, it was a simple tasks. I had ordered a new one but he was able to fix the one I had. On mine, the housing plate is busted, so I am ordering a new one. But in the meantime, he got me up and running for less than $300.
