EdMat
Well-known member
I think I have mentioned it before but this summer I ran over a racoon that came out of the brush on the side of the road determined to cross at a high rate of speed. Ran over it with the right front and rear tires. At one point all that was on the ground was the left front tire. Recovered and from cursory examination the results were coon 0 / spyder 1.
Well, since I have been on covid quarantine (I ain’t got it)
ray: because of being in close proximity to family members that caught it :yikes: I decided to update and redo a bunch of stuff on the spyder. Ordered in a slew of stuff. Started removing all the panels and the frunk. What I found was coon 0 / spyder .75
When I got the frunk off, I noticed cracking in the duct work and then in a couple of spots in the outer panels. Even one of the brackets that a push pin goes into had been sheared off.
I must thank IGETAROUND for his reminder of using some spare ABS and acetone to make a glue. That and some fiberglass cloth has got everything all patched up. Not perfect, but you must look close to find it from the outside.
Al that to say if I had just gone ahead and installed the bump skid a year ago when I was debating about doing it, I could have saved many hours of labor. Now I have the no light Spyderpops version and it was an amazingly easy install. Money well spent, just a little late.
