Will Sling-Mods Steering Damper make my Ryker's steering in general more difficult? How hard is it to install?
dryadsdad
I've recently purchased a 2023 Ryker Sport. We have uneven roads here, many of which are cambered. I've found the steering on the trike to be twitchy and in some instances scary. By that, I mean that sometimes I've hit a bump and the trike bump steered me toward oncoming traffic. This has resulted in me being constantly tense while riding, the polar opposite of what I'd hoped for in my motorcycle substitution purchase.
I note a steering damper offered on Sling-Mods' site. I expect this will reduce the bump steering but will it make steering in general, such as negotiating a road curve, more difficult? I'm at best a wholly untalented mechanic. Would such a cloddish fellow like me have a chance to get this installed properly?
Any other comments welcome.
I'll likely be purchasing a Ryker before next riding season. Two things will be installed immediately: BR sway bar/links; and a steering stabilizer.
It sounds like you are new to three wheelers.
Rykers take a while to get used to, give it a while.
A relaxed grip on the bars helps.
I do have a damper on mine and it does help with bumps and holes.
Steering effort might be a little more, but it's not bad. (Mine is set on 5 or 6 and I have a bad right arm.)
Go though some of the older threads and you will find a lot of people had the same problem (me included) at first.
Hope this helps.
Bruce/Raven
Fitted one onto my Rally, it's set to 6/10 on the clicker and works exceptionally well. Easy to install, an essential add on in my opinion... plus the swaybar upgrade.
Hope this helps.
Bruce/Raven
I am new, only hours into ownership.
OK, it turned out there was a difficulty right from the dealer. A friend of mine who's been a Can-Am rider for years (both of us two wheel refugees) suggested that my tire inflation was wrong. I checked, finding all were over-inflated, the right tire dramatically so! So I corrected that and will head out this AM soon to see if that helps.
I kept telling myself to relax my grip, but it was difficult when a bump would change my heading onto a Ford F350 coming at me from the other lane. I'm hoping for a mellower ride today, so that I can lessen my grip to where it should be.
As a fellow "two wheel refugee", I went through the same thing. Relaxing the grip and monitoring tire pressures helped some. BajaRon's sway bar helped even more.
YMMV
I'm just back from another ride. I'm beginning to wonder if my bike days are behind me.
Don't give up yet! The steering damper does help the darting about feel, even more will a proper sway bar. And time. 1000 miles or so to learn how to relax the grip and stop fighting the bike. Most people wonder if they haven't made a giant costly mistake until time and miles change that.
I'm going to hold on for sure. I'm just feeling a bit discouraged about it.
I was the same as you for a while... at least privately. It's a difficult transition moving from two to three wheels, but better than skipping to four. As for my 2cents... most of the sphincter moments will be at pace, so keep it way slow until you figure it out a bit more. For example, my cornering improved when I learned to slow down into them and accelerate out of them; I figured out you can't just jump onto three wheels from two wheels and try and keep the same pace, it's a whole new learning curve.
Rykers need a bit of set-up (most of my bikes did as well), especially if you ride at any pace. The Steering dampener and swaybar being the first bits. Stick with it, I'm glad I did... In my case my only other option was a convertible. :p
I haven't given up and don't plan to unless I despair. I agree that taking corners at speed now is uncomfortable but then again, I can't usually slow down all that much because I'd inconvenience traffic behind me.
It'll be one step ahead of the other. Based on my slight experience plus many posts such as your own, I'm disappointed in Can-Am for not fitting an OEM steering dampener.
I came from close to 60 years of riding two wheels when I had to quit.
Take a three wheel riding course if you can, it helps.
Find some back roads with little traffic to ride on for a while.
There were some back roads around here I could rail at over the speed limit on two wheels. But on the Ryker I was white knuckling at 40mph.
Three wheels takes some getting used to because you have three tracks to watch for. ( car- two, motorcycle - one)
A crowned road will pitch you around, but you are still going straight.
Just take it slow, don't let anyone force you into going faster than you feel comfortable.
If they want to pass let them.
Take your time, it will come.
We have all been there.
Bruce\Raven
