Will the BRP Vacuum clutch assist help with the hard pull clutch on a 2008 V-Twin?
rickster195752
I recently bought 2008 Spyder for my wife. she loves it, except the clutch lever is too hard for her to pull. anyone know if the BRP vacuum clutch assist will work on the older 990?
The 2008 came with vacuum assist - more specifically, pneumatic assist. See below, right from the 2008 shop manual. Start taking panels off. Would suggest that you check for proper solenoid and switch operation. Make sure that no vacuum lines have been plugged off. Clutch hydraulic service, etc, etc, etc. And no, that assist kit for the F3 is not backward compatible.
Screenshot 2026-04-02 at 7.15.26 PM.jpg Screenshot 2026-04-02 at 7.24.58 PM.jpg
thank you for this info- the diagra mm will be useful till my manual gets here. I did search through the older posts first, but didn't see any threads specific to the GS.
This bike is now 18yrs old, so several people have modified things; throttle body, clutch, etc. so I have to play detective and see what all has been changed...
Thank you for this - I haven't gotten a manual yet, hope to soon.
I assume that you have compared clutch force between engine running and engine not running, and finding no difference? And BTW, the 998 will use more oil than what you would normally expect. That's normal for that engine. But, if the clutch pneumatic diaphragm is damaged, it will REALLY use a lot of oil, possibly to the point of smoking. So, there's also that.
No charge for the Operator's Manual:
Shop Manual is 25 bucks:
Good Luck with it.
