Will these taller Tires work OK?
I have a 16 RTL found a good deal on tires 165/65/15 will these work ok they are a little taller than the oem or the size most are using.
https://www.tacomaworld.com/tirecalc?tires=165-65r15-175-55r15
I looked at that LINK and both sizes listed will work fine without issues ..... Neither of those brands are in the top 10 for Spyder tires ..... But both are way better than any Kenda ..... the Kumho is the better of the two ..... the best would be Vredestein Quatrac's ..... your money .... Mike :thumbup:
Thanks Mike the 165/65/15 i found is a Farroad for 57.00 each on.https://www.prioritytire.com/farroa...QGdSZ1dMzvoX91vEWQxalwi4v0RM3f0caAmO_EALw_wcB
Yes it will fit ...... As far as this tire goes ....I have never heard of it .... everyone says their tires are the best thing since sliced bread ..... very few actually are ..... any front tire on a Spyder should give you about 28 to 30,000 miles, some will give 40,000 mi..... divide the cost of that tire into 30,000 ..... then divide 114 into 40,000 ..... is it worth the difference .... your money your choice ..... JMHO ....good luck .... Mike :thumbup:
