WOLO vs STEBEL Horns
Mr. White
I am not sure which horn the vendor installed on Mr. Cognac. Which is louder and what model number is it. Your thoughts please. Thanks.
:spyder2:
I have neither on my spyder, but I installed the Wolo horn from Harbor Freight on my M109R, and it was really loud. Very good purchase. I am thinking of installing one on my spyder. But the electronics on this thing are so picky, I am afraid to touch anything myself.
I took off the left lower panel, used the existing wiring for the stock horn, added a short extension and mounted the WOLO to an existing screw with an angle bracket. Works great and it is loud.
Little checking..
They both have the same configuration so at a distance look alike. You just have to get close and you will see what is stamped on them for the name and model. I think they both only make one model compact air horn. Sound would be the same not sure on the decibles. Biggest difference would be the price...
:agree: The Wolo is a copy of the Stebel...
I don't know if there are differences in the quality, but I know that my Stebel is a definite eye-opener in traffic! :yikes:
There's a differnce!!
Have a bad boy on my V-Max and a Stebel on the Valkyrie ( recently sold it ). Both hooked up with a relay to the battery. The Stebel is noticeably loudernojoke.
Kaos
This is awesome, I couldn't make up my mind, I'm going with Stebel. I have a question if I install Stebel and leave stock on, do I just splice into horn switch? Stebel will have own power and relay.
Thanks in advance
If you get the Stebel, does it come with everything you need to install on a Spyder (in my case an 15 RTL) or are there additional parts needed (wires, relay, bracket etc)?
Thanks
Don
Thanks in advance
Connect the relay coil to the existing horn wires. You'll be OK. Run power from battery to relay contact terminal, from other relay contact terminal to horn, and horn ground to battery.
