PMK
In this case, I think it was just a design oversight. Not a choice to cheap out on a part. The proposed fix BRP has initiated seems to be working and will likely be used for factory assembly going forward at some point.
While BRP may implement the Loctite process and procedeure for new bikes, my hunch is they go cheap and either do nothing or keep it simpler.
Then again, BRP is infamous to overcomplicate stuff. Maybe they will skip the Loctite, save money by not using the bolt and simply weld the pulley to the shaft...
