Here's the part #'s for the '08 and the '11....lots of different numbers including clutch plates:
2008 GS:
1 420627260 Thrust Washer 1
2 420634476 Oil Gear Pump, 42 Teeth 1
3 420259535 Clutch Drum 1
4 420295783 Primary Drive Gear Ass'y. Includes 4 to 5 1
5 XXX Drive Gear 1
6 420239390 Disc Spring 1
7 420627910 Thrust Washer 1
8 420259588 Inner Support Plate 1
9 420238135 Compression Spring 4
10 420238140 Internal Compression Spring 4
11 420238130 Compression Spring 2
12 420247972 Spring Retainer 8
13 420247974 Spring Retainer 4
14 420941835 Flat Head Screw, M8 X 25 3
15 420247614 Spacer Sleeve 3
16 420259583 Outer Support Plate 1
17 232081414 Hex. Nut M8 3
18 420627220 Thrust Washer 1
19 420259520 Hub Clutch 1
20 420245830 Spring Washer 1
21 420242950 Hex. Nut M24 1
22 420259265 Plate, 1.5 mm 1
23 420659800 Friction Plate, 3.5 mm 9
24 420259260 Clutch Plate, 1.5 mm 9
25 420659791 Pin 1
26 420259519 Pressure Plate Ass'y. Includes 26 to 27 1
27 420632135 Ball Bearing 1
28 420238721 Clutch Spring 6
29 420627530 Step Washer 6
30 420241825 Socket Head Screw M6 X 45 6
31 420227180 Thrust Washer 2
32 420627230 Disc Support 1
33 420260890 Diaphragm 1
34 420627281 Disc Plate 1
35 420642055 Hexagonal Nut M12 X 1 1
B 293800060 Loctite 243, 10 ml 1
C 413711400 Loctite 648, 10 ml 1
O XXX Engine Oil 1
2011 RS:
3a 420685850 Primary Drive Ass'y. Includes 3a to 17 1
3b 420259533 Clutch Drum 1
4 420295787 Primary Drive Gear. Includes 4 to 5 1
5 XXX Drive Gear 1
6 420239395 Disc Spring 1
7 420626810 Thrust Washer 1
8 420259685 Support Plate 1
13 420247976 Spring Retainer 4
18 420627225 Thrust Washer 1
22 420259266 Plate, 1.5 mm 1
24 420259263 Clutch Plate, 1.5 mm 9
25 420659791 Pin 1
30 420640315 Hex. Screw M6 X 45 6
33 420260891 Diaphragm 1
2008 GS:
5 XXX Drive Gear 1
25 420659791 Pin 1
O XXX Engine Oil 1
2011 RS:
5 XXX Drive Gear 1
25 420659791 Pin 1
