Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
There were many reasons for the change of the site software, the biggest was security. The age of the old software also meant no server updates for certain programs. There are many benefits to the new software, one of the biggest is the mobile functionality. Ill fix up some stuff in the coming days, we'll also try to get some of the old addons back or the data imported back into the site like the garage. To create a thread or to reply with a post is basically the same as it was in the prior software. The default style of the site is light colored, but i temporarily added a darker colored style, to change you can find a link at the bottom of the site.
Is the belt riding against the rear pulley flange? Needs to be a credit card away going forward, not backwards. If riding without the proper clearance, this could make the squeaking sound. With a 2011 model, it could also be rear axle bearings. Check it out and get back here with a message so we can better diagnose.
Any Service history? Hopefully the rear bearings have been at least packed. Sorry, I'm not sure of the replacement mileage, but they should be checked & re-pack at every rear tire change (3~5k??) Also check the shock & that nothing's dry or rubbing, as things do get tossed up there.
Well, you're a good guy that gives a Spyder a good home. Now then, let's look up stuff and not go by memory. You have two different types of bearings on the rear wheel. The sprocket bearing is a double row bearing because it takes the stress of the belt tension. The wheel bearings are standard ball bearings. They are all sealed bearings with no periodic requirement to re-pack. I know, I know, there are those that say you can pop off the seal and shove some grease in there, but why would you do that for a 12 dollar bearing if the bearing is already squeaking. The replacement mileage is 31K miles or if it has been pulled out of the hub. I never replaced a wheel or sprocket bearing after 70K miles. They're that good. The same bearings are used from 2008 through 2021, I believe.
Let's focus on the belt. Get a bit of warm water and Dawn soap, wash the belt, leave it wet and soapy, and go out and test it the way that you know will re-create the problem. If the squeak is gone, then guess what? It's the belt. Check the alignment and re-align if necessary. Check the belt tension. There was a bulletin that reduced the belt tension on the pre-2013 Spyders down to 450n. Essentially, 100# with the frame jacked up with the rear wheel off the ground hanging by the swing-arm. Most techs forget about that and adjust tension to current values. Get yourself a Gates Krickit (Cricket) gauge.
There also was a bulletin to eliminate a squeak/squeal by putting a small dab of synthetic grease on the rear sprocket. Go ride it and let it work its way all over. It will eventually evenly distribute.
The thing is, if you are going to give a Spyder a good home, you need to do the maintenance. Here's an owners guide and shop manual. Good Luck.
New updated full digital version as of 5/2019 Professional Keyword Searchable Factory OEM Manual - 1370 Pages Covers the entire 2008-2011 CanAm Spyder RS / GS series (all versions) Contains over 650 pages of extra content that was not included in the book including: The full BRP 712-page...
Let's focus on the belt. Get a bit of warm water and Dawn soap, wash the belt, leave it wet, and go out and test it the way that you know will re-create the problem. If the squeak is gone, then guess what? It's the belt. Check the alignment and re-align if necessary. Check the belt tension. There was a bulletin that reduced the belt tension on the pre-2013 Spyders down to 450n. Essentially, 100# with the frame jacked up with the rear wheel off the ground hanging by the swing-arm. Most techs forget about that and adjust tension to current values. Get yourself a Gates Krickit (Cricket) gauge.
There also was a bulletin to eliminate a squeak / squeal by putting a small dab of synthetic grease on the rear sprocket. Go ride it and let it work its way all over. It will eventually evenly distribute.
Thanks. My Spyder is no cream puff, she's well used. They tried to sell me a new one, but I was like, nah this lil' Spyder needs me.
I'm glad I did, this thing runs like a scalded dog!
Had her up to 105 MPH, not bad.
This bearing can get a little loose in the sprocket/pulley. Grab the pulley and 6 and 12 o'clock positions and wobble it see if it has movement. This happened to mine many moons ago.
Also, I a great believer in flipping the bearing seals out and adding a few dabs of grease at every second tyre change - a whole lot easier than R&R with new bearing, which come with only a tiny lick of grease from the factory.
