2011 RT Ltd - left controller dead - anyone else had this happen? Any ideas/fixes? What causes it?
Raxxis
Hello all, I'm kind of facing a conundrum with my Spyder. It is at the garage at the moment and the repairman doesn't seem to know what to do with my case. The left controller unit doesn't respond to any command. I can't shift into gears, can't use the arrows, light switch, anything. The unit was replaced, but the problem still persists. Did it ever happened to you and if so, we're you able to fix it? Do you know what might cause this situation?
Long story short, I was driving in the city at a regular speed and decided to take the highway for about maybe 10 min. When I took the exit out, I got an transmission orange error message and an orange engine error message successively. No error codes were provided. The Spyder still comes on when I switch the key to "on" and it does start regularly when I push the Start button. Any help for this situation would be appreciated. Thanks. :)
Hello, and Welcome to the forum. The Left Hand Multifunction Switch is a CANBUS module. But, on the 2011 RT, not all functions are controlled via the CANBUS. Specifically, the Hi/Lo/Flash for the headlights (engine running for headlights) is a discrete switch not using the CANBUS. Also the Horn button is a discrete switch. All of the other functions such as MODE, SET, Windshield, Blinkers, Shifters, etc, are done via CANBUS commands. So, one thing to do is to determine if this is only CANBUS functions or all functions. There are two harness connectors to the module separating the two functions. You might want to check for harness issues further downstream.
You also might want to check Fuse F1 in the front fuse box.
Regarding fault codes - they don't just appear on your screen when something happens. They have to be in an ACTIVE state, then you have to push on a combination of three buttons for them to appear on the center screen. Unfortunately, those three buttons are on the left hand switch, and I don't know if it'll work right now. But you have to try. Turn on the key, and if possible, get the engine started. That will ensure the faults are active. While powered up (with engine running if possible) simultaneously depress the MODE, SET and TURN SIGNAL CANCEL (turn signal button straight in) buttons. If it works, and if there is a CANBUS communication issue with the left hand switch, you should get a boat load of "U" codes on the center LCD. Then your tech can look them up. Otherwise, you’ll need BUDS to find out what codes are being set.
I trust that your replacement module was the correct one. This is also going to be difficult to track down without BUDS and without a shop manual. Here's a link to a manual. Good Luck.
Snowbelt gives some very good advice. Try the horn button to start. If it works, that will be valuable information. It could be your ECM is having issues, or downstream in your wiring loom. Have you checked for a rats nest or rodent issues?
Thank you all for your advice, I've relayed the information to my mechanic to see if he can come up with something. I'll keep you posted.
So I've got some updates on my situation. It seems the previous owner took it on himself to install LED lights on the Spyder but forgot to ground the wires properly. In turn, this caused a major short circuit inside the Spyder and damaged the battery, which then couldn't properly power the left control unit. So by redoing the wiring, replacing the faulty LED lights, and changing the battery, my Spyder is alive again and riding perfectly. I'm beating myself for having trusted the seller from marketplace too much when I've purchased the Spyder and not having it inspected thoroughly. Lesson learned.
