Adding fresh fuel may have 'helped reduce' the risk if bad fuel being the issue, but it will probably still help to add some fuel conditioner/injector cleaner to the new gas you've added to the tank, then while holding the throttle fully open, crank the starter for a minute or so to try and get some of that fresh fuel into the lines & injectors, and maybe dissolve any varnish that may have formed &/or at least start to clean up any corrosion in there before you actually try to start the engine - and doing that will be hard on the battery! :lecturef_smilie:
So you said you'd replaced the battery, but did you make sure the replacement battery was set-up and fully charged properly
BEFORE you installed it?? Unless
YOU did that, even if it was brand new, then it most likely wasn't
fully charged before you installed it; and if it was a retail purchased AGM battery, there's a good chance that it never got the necessary 'standing period' before they hit it with their initial charging either, which was also most likely just a very cursory 'fast charge' at best!! All of which means that maybe your 'new battery' just isn't up to the task of starting all the power hungry screens and computers that these Spyders have at the same time as cranking it for long enough to actually get the engine started?? :dontknow:
Have you checked your battery
since you've had all this 'no start' stuff going on? If not, you should; and it might pay to put it on a proper 'slow charge' for 8+ hours anyway?! Not saying that this battery thing is definitely the issue facing you, but if
YOU haven't done any of that ^ since buying that battery, it's extremely unlikely to hurt anything; and working that in with all that fresh fuel, fuel condition/injector cleaner, and the WOT cranking stuff, it
juuuust might get your Spyder going again?!
Go on, Try it! What've you got to lose?? :thumbup:
