Roadsterryder
Today’s report….lol. 3 trips (around 8 miles total) around town and she started every time. Took the Tupperware off on the left and located the crank sensor. Removed it just to see if there would be any metal pieces on there like someone else in another forum suggested. Looked clean just oil on it. Installed it back in the housing.
Seen a little oil around the cylinder all the way down past the output shaft to the oil filter area. It must have seeped out somewhere over time because it is all caked on to the engine with road dirt/dust. So my question right now is can I spray some engine cleaner/simple green on there on hose it down without causing any more problems? That way I would be able to eventually see where the oil is coming from.
And also something I was wanting to pass on…when I removed the MAP sensor to replaced the hoses I noticed the MAP sensor was kind of loose inside the little plastic housing where the hoses attach to. It was loose only in the area where it would be all the way seated down. Pulling it out of the housing it became tight again on the way out. The green O-ring of the MAP sensor was all flattened out. So I tried to find a new O-ring at the Autoparts store but no luck. Back at home I took my heat gun and applied heat carefully to the O-ring area. It didn’t even took 10 seconds when I could see the O-ring went back to it‘s original shape and the material felt soft again like a normal O-ring. Then when I reinstalled the MAP sensor back into the little plastic housing with the 2 hoses it felt tight all the way down. No need to replace the sensor.
