ChrisW
First buy an adapter socket as shown. Then enlarge the hole in the socket by drilling out with a ¼” drill bit so it will fit over the upper round brass part. Next remove the rubber antenna top/cap and slip the socket over the end and down over the upper round brass part onto the brass 7mm nut. I used a 13mm box to go onto the socket and undo the antenna without messing up the end almost at all.
Got this from Lowes.
The socket that comes with a hole thru it.
and wha'la there you have it.
