Has anyone else's 2022 Spyder RT Limited made this loud noise? Any ideas?
dbrown395
Hey folks, this has happened 3 or 4 times. When backing out of my driveway very slowly, or even going forward, with a passenger (130 lbs), I heard a very loud snapping like sound coming from the rear of the bike. It literally sounds like the frame has snapped in half. I looked underneath for anything obvious but didn't see anything that stands out. My driveway is about 1 inch higher than the street. The Spyder runs fine, and makes no noise while riding. It has about 8,000 miles now, but also made the noise when I had about 5,000 miles on it. Just wondering if anyone has experienced such a noise coming from the rear, or would have an idea what this may be? I will most likely take it to the dealer if I can't figure it out. Thanks in advance!
Have you checked the Front Sprocket for any signs of movement, wear, red dust, etc?? Or had that sprocket replaced?? :unsure:
Apart from the Front Sprocket skipping on the splines, the only other thing I can think of that might easily make that sort of noise is a skipping belt - have you checked your belt condition & its tension?
They might be SWAG's, but then again, it might be worth looking carefully at those?! :unsure:
Good Luck! ;)
