Marker
What a great looking Spyder! Congrats. I'm looking into installing a fuse block myself could you give me more details on what you did to help spark ideas. Thanks in advance and again great job!
Well for one thing I left my heated corbin seat on and it killed the battery so I wanted a keyed switch for the seat. I also keep my spyder parked outside in the summer under a cover so I did not want mice in it so I found and installed a electronic mouse detterent. I installed driving lights because to help see better at night because we ride a lot of back roads. With having said that I wanted all the electronic accessories separately fused from the spyder and independent of the spyder fuse blocks. If I have any problems witjh the electronic accessories causing spyder codes I can disconnect the entire fuse block from the battery.
I found out about fuse blocks and accessories from this web site . Spyderlovers is awesome for information. The fuse block I have has two sides one hot all the time and the other side only hot when the ignition key is turned on.
I hooked a trigger wire to the LED accent lights in the headlights.
