2015 RT - trying to swap the Garmin mount with a powered cell phone delete mount - any suggestions?
Scooter13
I’m trying to figure out how to swap the Zumo Garmin on my 2015 RT Limited with a powered cell phone mount, or just a cell phone mount.
I use the mapping program on my phone for navigation and the Garmin is not being used.
Any suggestions would be appreciated.
Thanks in advance,
Scott
Replace your fuel or temp gauges with USB connections or cigarette lighter ports. Also, there's a USB port that will fit below the center of your handlebars between your rocker switches. Temp and fuel readouts will switch over to the screen between your tach and speedo. You'll have 12v connections coming out your ears, almost.
If it's stock, it'll be wired all the way back to around the rear passenger covers. I found the best way was to remove the headlight to see the power wires run down the steering area. Then back to the passenger side behind the covers. Right side.
