vienna7475
I recently purchased a 2015 Spyder RTS with 2700 miles on it. The only mod so far was to add the BajaRon Sway Bar. I've put over a 1,000 miles on the spyder and have been reading lots of posts concerning how the spyder handles. This is what led me to install the sway bar right off. I've now experimented with tire pressures from the numerous opinions. The spyder still has all factory tires. Tire pressures when I received the bike from the dealer were Front - 22, Rear - 30. After twitching all over the road and multiple test rides I've ended up with Front - 18 and Rear - 22. What a huge difference in handling. The spyder doesn't twitch like it used to on interstate at 70-75 and stays pretty stable when getting wind buffeting by 18 wheelers. I do get belt vibration when I hit 70 to 75. Vibration tends to stop once cruise is set. Vibration most apparent when throttle is under load getting to speed. Will be getting belt tensioner.
Now that you have the background details let me tell you about the new sound. I was able to post a video on YouTube
where I was able to capture the sound. I'm riding the spyder in a parking lot in a circle to the right and then left. If you listen closely you can hear the sound. It sounds like a rubbing noise. I've also coasted down my driveway with the engine off and can hear the sound as well. Wasn't able to get a good video capturing the noise so the first one will do. My inclination is to think the belt is now rubbing on the front sprocket. I've noticed since I've reduced tire pressure in the rear the belt now makes a slight pinching noise when I roll the spyder forward or backward manually. It never did this before as I rolled the spyder out of the garage several times to move it around.
I've also attached pictures of the front sprocket. You can see in picture 2 and 3 the belt doesn't look like it has ever ran against the inside of the sprocket lip as there appears to be about a 1/8 area that doesn't show any wear. You can see that the belt has ran against the outside lip at some point as the splines are all shiny. I haven’t smelled any burning rubber like some users have talked about the belt.
Now to my Question.
Right now when I crawled underneath to take the pictures the belt is sitting pretty much center on the front sprocket. So my question is does anyone think the change in the rear tire pressure has affected how the belt is running on the front sprocket and does anyone think the noise is coming from the front sprocket. The noise doesn't sound like a wheel bearing noise to me and I would be surprised if wheel bearings went out with just 4000 miles on the bike. My inclination is to just be cognizant of the noise for now and keep an eye on the drive belt and see how this progresses.
I've also added three pictures showing the rear sprocket and side shots of the belt.
Pic 1
Pic 2
Pic 3
Rear Sprocket 1
Rear Sprocket 2
Now to my Question.
Pic 1
Pic 2
Pic 3
Rear Sprocket 1
Rear Sprocket 2
