2016 RTL side case - front latch will not latch. Anybody else? Any fixes?
Baird4444
Rt. side case latch, the catch on the front will not "latch" so just the rear latch is holding, but not well. I can
flip the rear latch closed with a screwdriver and release with the handle. The front latch rotates but
will not "catch" and stay latched. This is more than a cable adjustment, right? I'm guessing the front side
latch is discombobulated... Anybody else seen this and dealt with it?
Also... where is the sensor for the "rear case open" light? I don't see a micro switch...
Thanx for any input - Mike
Pictures would make it easier to understand what is happening. You should look to see if the side case has shifted, maybe one of the hinges is loose or moved, maybe the latch itself has loosened or worn out. it could be a number of things that can cause a misalignment.
