KenF
Hello Ladies and Gents,   My 2020 Spyder RT Limited decided to rudely burn out a rear turn signal bulb.  The owner manual states this bulb is one of three bulbs that are not LEDs, but does not say what the replacement is.  So, I went to my CanAm dealer to get a bulb and lo and behold they could not find it in the parts catalog.  No bulb was even shown!  I came home, got on this forum and searched for others with this problem.  finding enough information, I ordered two 7507LED bulbs (BAU15S) from Amazon.  After three hours of work I now have LED bulbs in both rear turn signal with no hyper-flash.  The OEM bulb is a 2641A that has the side pins at 150 deg.
Below is a message I received from Amazon:
Count Product Name and ASIN
1 OXILAM 7507 PY21W BAU15S LED Bulbs Amber Yellow 2800LM for Turn Signal Lights with Build-in Load Resistor CANBUS Error Free 2641A 12496 7507AST Bulb R
ASIN: B07RMX2XK6
Dear ,
Good day to you.
Thanks for your order of our items: 112-9480360-0230652 .
Here are some warm tips when using these bulbs:
1. For a few sensitive vehicles the built-in load resistor may be not able to solve the hyper flash, and extra load resistors maybe required.
2. These LED bulbs are replaced for Standard BAU15S base interface, the two contact pins are at a 150 degrees angle, replaced for BAU15S, 7507, PY21W, 2641A, 12496,7507AST etc. They are used as turn signal lights ONLY.[/COLOR]
If you meet the above issue when using these bulbs, please reply this email directly with your complete car model, including year, brand and series. We will try our best to solve your problem.
Best Regards,
OXILAM TEAM
I hope this information helps everyone who should need to replace a rear turn signal bulb.
Ken F.
ASIN: B07RMX2XK6
Dear ,
Good day to you.
Best Regards,
OXILAM TEAM
Ken F.
