robhowen
The following photos and description are of the removal and replacement of the Side Access Body Cover that you need to remove for an oil change, access to the brake fluid reservoir, and likely other maintenance needs.
Lift the driver’s seat.
The cover is held in place with 6 automotive style clips. Assuming you are facing the side of the bike, you remove the cover by pulling towards you (not up or down), beginning with the rear (closest to the seat) upper and lower clips. For me the bottom rear clip pulled out quite easily. The top rear clip was so snug that when it gave way (scary squeaking sound), all of the clips came out except the most forward clip. After removing I put a very thin film of silicone grease on each of the metal clips.
I reinstalled the cover by inserting the forward-most clip and then positioning the cover where each clip was in place and then applied minimal pressure to hear each one clip into place. In summary, not a big deal once you’ve done it once.
The following four photos show the cover, clips, clip locations, and a close-up of one of the clips.
Rob
Rob
