2024 Dash Display suddenly changing &/or freezing - anyone else? Any fixes?
I'll ask again about the displays in question, Are they being exposed to direct sunlight when these issues are happening? I used to work on the DMV's version of ATM's called ETM's and they would have numerous issues when the display was exposed directly to the Sun and it would overheat causing the display to start "locking up" and would eventually end in failure or "going dark". Once I recommended awnings to shade these devices they would no longer have issues with the machine.
I know you might think this silly, but screens going black and then having to roll the throttle to get past the warning REALLY smacks of a dud or dying Spyder battery!! :oops:
If you've got a 2020+ Spyder that's having any issues like this, and especially if the battery is still the OEM Haiju or whatever battery, then so many people have had problems with them that yours has got to be suspect!! So if you do have one of them, I'd suggest that it's likely well past time for getting it load tested and looking for at least if not better than 12 volts under load... they really are crap batteries that aren't properly suited to the task, and from numerous owner's experiences reported here on the Forum, one of them lasting anything much more than 6 months and still being able to run everything properly all the time is beginning to look somewhat akin to a full blown miracle! :eek:
You might scoff at the idea, but seriously, why the bleedin' 'eck are any of you continuing to put up with these symptoms without doing this most basic of tests?? What can it hurt to check your battery properly and remove any doubt about it being at least a part of your problem?! :unsure: Sure, it might not have anything to do with whatever your Spyder's doing, but there's enough people reporting similar issues here that're ending up being resolved by replacing the crap batteries that anyone experiencing these sorta freezing or blank/black screen problems without doing that load test first up and confirming that it's not (or otherwise) the battery, everything/anything else you do could be a complete waste of time!! 😖
Just Sayin' ;)
I have a new Motobat battery and it’s very strong. I'm not saying it’s not the battery, but I highly doubt it. I have a tester and I will do that, but the screen froze on CarPlay map stop could scroll anywhere for about 20 Km’s ago before didn’t notice, but it's not like I look at it all the time…
As well, I had been riding for about 6.5 hrs that day, so that would also mean the charging system is screwed.
So I check the update I had the latest firmware, BUT there seems to be a revision with the same numbering? Anyway, I did it so will see. Today was cleaning the bike and yard work, tomorrow another ride.
Mine wasn’t directly in the sun at that point, it was partially cloudy 🌥️
Thanks, so that can be eliminated . I have seen a good bit this on other equipment with LCD displays and wanted to help rule it out.
We did a few rides, 350 Km’s or so, and no other issues. I’m hoping this was the first version of the firmware that wasn’t playing nice. I will keep an eye out for that.
I wanted to get in on this conversation. I have a 2024 S2S and have the problem of the screen just going blank while riding and the only way to get it to reset is to stop; turn the bike off; and allow it to fully shut down. After this, when I turn the key back on, it works fine. I don't use CarPlay. Here is my journey to this point:
  1. - Picked up the bike in July 2024 with a trailer hitch and wiring installed by the dealer.
  2. - I installed a GARMIN GPS.
  3. - First time it happened was later in July.
  4. - I contacted the dealer and they were working with BRP to find a solution.
  5. - I installed additional lights.
  6. - The issue is unpredictable, it happens in hot, cloudy, and cold weather.
  7. - October 2024, the dealer was directed by BRP to replace the wiring harness, I could not make it to the dealership before the snow came.
  8. - April 2025, I had to install a new battery (I had a contractor unplug the trickle charger in Nov 25) - living in Canada, there is too much snow to ride from Nov thru Apr.
  9. - May 2025, the dealer installed a new wiring harness.
  10. - Jun 2025, I did a 3,500km trip over 7 days with no issues.
  11. - July 4th, I did a 250km trip, but about 20 km before getting to our destination, the screen went blank again.
  12. - BRP has released new software that I installed on July 21st.
  13. - I'm now waiting on the dealer and BRP to come up with any other/the next steps.
The biggest problem is that I cannot find any way to repeat the problem. This make it more difficult to trouble shoot.
I would like to know if anyone has had similar issues, and what solutions you have seen that fixed the problem?
Thanks
