A fun time installing my BajaRon sway bar and links
jegarh
Today it was misting so I decided to install my BajaRon sway bar and links on my 2014 RT. I pondered ways to lift it and decided that the best way forward was to drive it over the pit that we use to service our other vehicles. This was a brilliant idea until we noticed that the bar was hitting the edge of the pit when we tried to remove it. After jacking up the right wheel another 8 precarious inches the bar swung down and we were on our way. The actual installation went smoothly. Now the only thing left to do was to reassemble this Chinese puzzle of screws, push pins, bolts, shields and body panels. I intentionally left off the spray shields that are under the engine. I welcome any comments on this decision.
Changing the oil over the pit is going to be a piece of cake.
My hat is off to all of you worthies that installed your BajaRon sway bar laying on you backs under a 900# dead fall. :bowdown:
Jerry
Yeah.....I was cursing it too, Jerry.....but I felt quite safe with the supports under the front axles, even though I had to lift the F3 off them to get enough height. The worst part is getting those bloody push pull pins back in to the protectors after your neck and shoulders have stopped working and are aching like mad ! I nearly left mine off too ;)
It was worth it though.:thumbup:
Well done...
congrats...and well done... :2thumbs: of course now you are going to have everyone digging themselves a pit....:roflblack: your gonna need to post the spec's...
Hahaha.....if I dug a pit, I'd have my wife standing next to it with a shovel just waiting for me to climb into it, Gene. :lecturef_smilie:
Jack stands
Big Jack stands, piece of cake! Really helps to have a partner! More helpful if she is hot! 😄
......and a big jack, Joe.. I had to jack it up, put it on the stands, lower the jack, add wood blocks to the jack, jack it higher, oooops, no more height on the stands, leave it on the jack to drop the bar, feeling uncomfortable the whole time.........all my fault of course.....5 minutes at the start measuring my maximum jack height as per Ron's instructions would have told me my gear was inadequate without modification. Mind you, I still would have had to do the same thing I did because it's hard to justify the cost of buying new stands and/or jack, just for a single install.;)
Sometimes I wonder if you guys are having more fun putting it on than having it on! :rolleyes:
Just goes to prove there is more than 1 way to skin the cat! :thumbup:
Wheels
Jacking the bike high enough can be done in steps. Once high enough, platforms or stands below the wheels will provide a safe workspace. We bought stands for the job, but we do a lot of them. Being safe is priceless!
Hahaha.....for me, the bar is worth every penny and self introduced installation frustration, Ron.....:thumbup:
I used two motorcycle lifts under the front tires and had my wife running around the garage screaming about how it was going to fall the entire time I was changing it out.
That's how I felt the first time we installed one. Now that we have the proper equipment it isn't scary for me but sometimes I think our customers might want to scream too.
What's the difference in clearance?
You need 22" from the bottom of the frame bar to the ground on the later models, Stumpy. I don't know how much you needed on the earlier models, but my 8" ramps were short by about 8". I needed some 4"x4" on top of my Harbour Freight type lift at full extension to get just enough clearance for the F3.
