Accessing Rear Light Connector - Push Pins ruined - any sources or alternatives?
JohnRtl
I am looking for a cable to power some small LED strips which I intend to put behind my top speaker grills.
The reason for this is that the indicator warning lights are tiny and way down at the bottom of the console. I want something a bit more obvious to warn me. I find the indicator button doesn't give a great deal of feedback - there is no sensation of it clicking off, and hardly any movement at all. Ditto when I turn them on - very little feedback.
But that is a long way down the road yet. I've made the small LED strips. I just need a feed. I checked out the front indicators - my tryke doesn't have any in the rear view mirrors and I couldn't easily find the connector at the front. I couldn't see anything obvious from the photos that I took when I had the front dash off - so I have reverted to the rear indicators.
I used this video to give me a clue as to how to access them. Fairly easy but a bit fiddly with 3 different Torx size drivers required and 4 push pins.
The push pins proved to be a problem, but I got them out (more later), and accessed the connector, took photos and found that it appears to be a Delphi PBT-GF20. It turns out that the PBT-GF20 is nothing more than an indication of what it is made of. The Delphi GT150 seems to be the type that matches what I found - except Delphi is now called 'Aptive', and I managed to find somewhere that sold the matching male/female parts including the terminals and seals. So there goes my self imposed rule concerning buying from China.
So hopefully when they arrive I can get back in there and intercept the wiring harness.
The push pins to which I refer are not push pins - they are like a push pin, but they have a plastic screw. I have always found this type of fitting to be a pain. They work to assemble, but they don't come out easily. This was no exception. Turning the screw resulted in the whole lot turning very slowly. It would not budge. So I ended up drilling the screw out and that enabled me to insert a wood screw and pull out the main body - which remained intact. I wasn't too bothered about this - cos trim clips like this are pretty common, aren't they? Well that's what I thought. I have some in old tobacco tins.
But the one that I removed are 35mm long and fit into a 7mm hole. None of mine came close to fitting - when I tried a shorter one, it just pulled straight out. Hunting over the internet reveals that the longest I can find is 22mm for a volvo.
If I put a 4mm drill bit, shank first into the hole, then it spreads it wide enough to lock into position. So if I can't find anything I'll find something that will do that. I don't want anything metal because if I do that and it gets stuck again, drilling is not going to be a solution. I can't use normal push pins because the head is buried quite deep inside 4 holes around the pannier 'pocket' where the luggage sits - so it would be impossible to lift the head.
Does anyone have any brilliant ideas please?
[edit] I found a fiche at last - and thanks to the posts below that pointed me to others - and the part listed is the same as the push-pin that is used elsewhere on the Tryke - eg top side edge of the ‘frunk’. I’ll try those then - as soon as I can find a way to remove them from depths of the deep hole in which they are located.[/edit]
I believe the CAN-AM part you're looking for is 293150230 which is also called a Tuflok Plastic Rivet.
You can buy them from CAN-AM, but they're expensive.
I found a bunch of eBay listings for them, some that were reasonably priced for 10 or more, and some that were seriously delusional in terms of price (1 for US $24.99...with free shipping!).
I usually start at https://www.canampartshouse.com when I'm looking for something. A bit hard to navigate, but eventually I find things.
Thanks @racoon - I have a bag full of those particular ones, but the ones that I removed were much longer and had a plastic screw as the centre piece.
I found a fiche at last and indeed it shows the rivet that you mention for that location, of which I have about 50. I guess that the previous owner decided to fit screw types. I can imagine that removing a push pin rivet which is situated at the bottom of a deep hole would be quite challenging. I think I will embed a long thin screw into the top that I can grab with a pair of long nose pliers, or thread a long cord around the rivet head so that I can pull it out. Or at the very least, drill a shallow pilot hole and buy a long drill bit so that I can drill it out if I need to.
That's a material code abbreviation for 'PolyButylene Terephthalate - Glass Filled 20%'.... a type of Polyester with reinforcement courtesy of the addition of 20% Glass, usually in the form of Glass fibres.
The push pins with screws in the middle should be outlawed by a Hague convention. Their usefulness is right up there with chocolate frypans.
Ok - I took off the part surrounding the right hand pannier completely and had a good look at the holes that are in the plastic that remains and in the part that I had removed - and I observed what happens with the 293150230 plastic rivet.
Putting it in is tight. The outer piece fits OK, but the plug takes a very firm push to get it into the locking position.
The taking out is a doddle it comes straight out as it is with the pin in place ! I checked it out a few times in a couple of easier to access holes.
So I reverted to the long screw/push pins that I had removed. I found a metal screw - far too long - that screwed or pushed into the centre and which opened out the bottom end of the plug. Then I tried it in the hole. And the pin and screw stayed in place. So the only thing to do then was to shorten the screw.
So its all back together again. (Again). I don't really understand. The fiches clearly indicate that it is the same push pin that is used in many other places - but for my tryke, it isn't working. Which is possibly why it had the plastic screw type spreaders.
Thanks for the comments and suggestions. I thought I'd feed back.
