OK, I warned you all - is this oil level high? Should oil smell like this? Should I drop the oil level, or just change it? And more...
spydersense
So I already did a search and really couldn't find what I was looking for. Here's my plight, just purchased 2023 RT with 10,400 miles on it. I took a gamble, bought it sight unseen from a trike dealer/manufacturer in Alabama, and it just arrived today. So far everything seems as it should be. I checked the oil and here is where my dilemma begins. It looks like the oil level might be a touch high. It appears (?) at the top side of the upper round ball on the dipstick. Frankly, the oil looked good, so I smelled it. Never in all my life have I ever checked the odor on the dipstick. I feel like there is a slight hint of gas. My question is, is this normal (combustion inefficiencies) or concerning? Should I drop the oil level down a little, or just do an oil change which I'm considering.
Couple other questions; the oil dipstick is very tight, had to use a crescent wrench to rotate it., and next is the smell of burning plastic. Seems like at 10,400 miles most of that should have been burned off by now.
Its raining now, so I wasn't able to give it a good test drive, but I did drive around my block. Everything else seemed fine. I feel like a first time father after bringing the little golden treasure home. But I did warn you in my intro post. Thanks in advance.
I don't know if you have familiarized yourself with the correct oil check procedure for the dry sump engine in your Spyder. If so, just ignore all of this. If not, here goes:
  1. Get the engine up to normal operating temperature.
  2. Park it on a level surface and let it idle for a couple of minutes.
  3. Shut off the engine, and read the dipstick.
If you do anything other than this, your reading is likely to be wrong.
Be sure to read the owner's manual cover to cover a few times, ESPECIALLY how to check the oil level! The Rotax 1330 engine has a dry sump oiling system. For a new owner it is easy to overfill. NEVER CHECK THE ENGINE OIL AFTER SITTING ANY PERIOD OF TIME (like overnight) - NEVER. The manual says to ride for 10 Miles, then let the engine idle for 10 minutes (I only wait for a couple of minutes to let the scavenger pumps work fully), turn off the engine, and then immediately check the oil level (I believe the manual states that one has a couple of minutes to do this in, but no longer). The oil level is difficult to read on these dipsticks, so I use a white paper towel behind the dipstick in direct sunshine to make it easier to read. These engines are great at not using oil, so if you check your oil level after a ride and there is no oil on the ground before your next trip out, your engine will still be full of oil and ready for the next ride. Enjoy the ryding time the Spyder offers, I know I do.
I have had some difficulty in some vehicles getting the threaded oil dip stick loose. This is especially true of my 2022 Ram pick up. I believe my 2023 RT gave me some difficulty when new and then I just used a small pair of pliers or an adjustable wrench to loosen it. If it were me, I would do an oil change with filters first thing, that way you KNOW what condition the oil is in, how many miles before the next oil change is needed, and that it is filled PROPERLY.
Who knows how long that oil has been in the engine. Good oil is cheap insurance, so if you are concerned, then just change it (and the oil filter) and refill according to the volume of oil specified in the manual. I've never refilled mine by reading the dipstick. My dipstick is hard to release too, so I wouldn't panic. I can't offer much about the smell of burnt plastic, other to get underneath & check to make sure that there's nothing plastic touching the exhaust.
I remember when I first got mine, the dipstick was hard to turn. I think the reason was the previous owner hadn't driven it for awhile. When I put it back in, I didn't twist it enough and it started dripping when I got home after a ride. It's still hard to turn either way, but at least now it doesn't feel stuck.
The dipstick is hard to read, as Redbeard said, a piece of paper towel works.
Mine holds 5 liters right to the full mark, so I get the oil, Rotella T6 in the 5L jug; least ways, I did 'till I bought the 18.9L pail and now I refill the jug.
Yes, just change the oil and filter and be done with it. Then you know it's okay. You say you bought it off a dealer/manufacturer of trikes, so I'm guessing they have never dealt with a Rotax engine before. There's good advice in this and many other threads on how to check the oil level properly and how to change it, and how much to put in it (with and without a filter change). Be careful about wrenching on the drain plug - use a torque wrench and the proper gasket. You can get all of this sent to you by @BajaRon
Regarding the gasoline smell in the oil... check it again after you drain it for the oil change, and well away from any other gasoline sources. If there's still a strong gasoline smell, then come back on here with that info and get some advice.
First off, have you owned a Spyder before this one?
Just need a little more information from you.
Over to you. Let us know.
