SpyderHands
Has anyone installed a 12V accessory outlet on their F3?
If so, please share.
Thank you!!!
:thumbup:
Thank you!!!
:thumbup:
yes.
Real easy.
The customer accessory circuit under the rear seat comes in a boot and there is a knock plug to mount a socket.
Another circuit under the left service panel
The third in the battery compartment.
All marked customer accessory circuit.
Thanks for stopping by.yes.
Real easy.
Not wanting to do that personally. :sour:I remember seeing post where someone drilled a hole through the left side service panel and put a plug there, any one have any regrets about doing that
pros and cons
If you mean the dc plug, Amazon has the exact same item much cheaper.Thanks for stopping by.
Did you get the AC adapter from BRP or elsewhere?
Thank you! That's what I was referring to.If you mean the dc plug, Amazon has the exact same item much cheaper.
I'm looking for the Plug & Play 12V plug for the F3 dash and the USB plug for the other slot on the dash. Any online sources?
