adjusting headlights
There is a step-by-step procedure in your Owners Guide. Basically you stick a long Phillips screwdriver in the hole beneath the lens, and screw it up or down, while shining it on a wall to test the height, and keep the lights even.
And make sure and SIT on the bike one or two up with or without gear-- depending on how you usually ride.
Copy that Dan. I made the error of not having approximate rider weight on the seat while making the adjustment. I was getting a lot of high beam flashes from oncoming drivers. But Scotty pointed that out, I made the correction and now they are just fine. Thanks again Scotty! :thumbup:
I want to add that you have the high beams switched on while you adjust these to them mark on the wall.
