Aluma 638 trailer, where to place tie down points?
Where do I put tie down points on the Aluma 638 trailer, to hall the Spyder
Pictures would be great.
Thanks
I'll add my experience to this conversation. Last year I purchased an aluminum trailer, same one as at Tractor Supply. It's has a 10 foot X 65 inch bed with a ramp on the back which can't be used because it's angle is too steep. I used the clamping package as noted from Walmart, but, found out that you don't need (can't use) the back chucks because once you drive forward on them, you'll be hard pressed to get the wheels to back out of them. Skid marks on my trailer attest to that. Anyway, I took the aft chucks off and just used a short e-track plate instead. It's just as solid. For the rear tie down, I place a strap around the rear peg going down to a ring and back to a tie down point. Took a 2K mile trip this way and nothing moved or slackened up even over some rough roads. I ended up using three bike ramps to load the bike. I shorted the center one by 12 inches so that the nose doesn't contact first before the wheels start onto the ramps. I have several pictures of my setup and will try to attach them. The pins on the ramps fit over the rear frame into holes in the wood floor to prevent them from moving. I have since removed the trailer ramp (useless) and increased my gas mileage by 4 MPG. View attachment 189384View attachment 189385View attachment 189386View attachment 189387View attachment 189388View attachment 189389View attachment 189390View attachment 189391View attachment 189392
All the dang pictures are upside down. :banghead:
Opinions please: I have to take my RT somewhere first thing in morning about 150 miles. I have only tied down motorcycles so need a quick read of my tie down. I have an Aluma trailer and have looped two tie downs through rear wheel and tied off at 45 degree angle. I looped a strap through both front wheels and tied off at 45 degree angle. The brake is on and gear in neutral. Bike faces forward. The straps are very snug but not he-man tight.
I don't have time to acquire gear for some of the methods listed here so hoping this will be adequate for now. I seldom will be trailering it.
I had to crawl under and really look for good tie down spots. I have a really tricky tie down situation to do this June. There are 2 very easy solid tie down spots under the older spyder 14-19 RT. Stick your hands under the spyder right where the swaybar channel. There are 2 2inch holes in the frame facing forward and reverse. It’s solid steel U channel that is part of the frame. Put a ratchet strap hook in the hole and crisscross left to right. You don’t need to lay down even to hook it in. Come in sideways. I use a strap over the rear tire and crisscross the front and it can’t move.
