BamaJohn
Well-known member
Before anyone posts that my pipe dream is impossible to have...I can still dream, can't I?
Every time I need to do any maintenance on my 2020 Spyder RT I wish it had a powered piston center stand that would raise it at least 4' inches. Concrete gets harder each year, and that would help with the following:
opcorn:
- check/adjust the rear tire pressure
- change the rear tire
- change the engine oil
- adjust the side cases release cables
- rotate the rear tire to inspect for wear/foreign objects
- raise the trike higher to work on topside stuff without bending over
- other things
