bushrat
Here's what I'm using...
Not to hijack EvilTwin's thread, but since others have chimed in about alternate trailer choices, and some have asked questions re measurements (minimum requirements), I thought maybe I would post some pics and comments about my own little rig. This trailer was designed by a friend to haul his Spyder RT to FL and back (ON); it has made about a half-dozen round trips over the past 5 years, all without incident. The trailer is welded aluminum throughout, and was built at a fabricating shop to his custom order. It is officially registered as 'home-made' with a weight of 350 lbs. Overall length is 12'; bed length is 96" and bed width between wheel wells is 66". Tires are 13". Rides on a 3500 lb. drop axle with leaf springs. Bed height is about 12" above ground level. In short, a strong, light weight trailer; doesn't have full floor or nose guard. A sort of 'minimalist' trailer. An RT will load with 2" clearance either side; my F3 has 3-1/2" either side, and I use a 'finished' 4"x4" block on the outside of each front wheel to prevent sideways creep. The front wheels ride against the short plates at front of bed, meaning that the nose (frunk) of the Spyder is somewhat over the spare and just misses the tongue jack. Photos show the tri-fold (hinged) side ramps which fold onto the side planks of the trailer; the third ramp for rear wheel lifts off and is bolted to the frame below the Spyder when travelling. Handles well at Interstate speeds. I went south last fall without a cover and had torrential rains. Coming north, I used a BRP trailering cover, and found I got lots of dust collecting underneath; nothing a good bath won't fix. No other issues so far. Load-wise (with Spyder on-board), I'm hauling less than 1400 lbs. total, well within the capacity of both the trailer axle weight and my vehicle's towing ability. Could probably even tow it with my Spyder if I had a hitch. Very light to move around when storing.
