Any LED light recommendations for my plate??
skbower24
I am looking for recommendations and where to purchase an LED light for over my plate. Looking for something smaller so it is not so noticeable. Any help would be appreciated.
Maybe JP Cycles?
Tell me about your license plate re-locater if you don't mind.
What's the advantage of removing the rear fender that creates plate and light relocation issues? Is this a aesthetic modification or are there issues with the rear fender and the fender extension that was added?
I'm wanting to change out the bulb on my Spyder for an LED, and am considering modifying the housing to accept this:
https://www.amazon.com/gp/product/B07F9JGVCH/ref=ox_sc_saved_title_2?smid=AEOL7V7GD2B8G&psc=1
Perhaps this would work for you as well if you relocate the existing wires over to the new plate location.
:cheers:
on my 09 RS got a frame from cycle gear with LED's for license plate, turn, run, and stop. still got it in the garage trying to see if I want to put it on the 20 RT
If you are deleting the fender why not use the power source for the fender light and reroute that wire?
The chopped fender kit came with its own harness, but I wanted a side mounted plate. I simply routed a piece of 18 ga two strand wire from the side mount.
