Any Mounting bracket and switched power tips for mounting a Garmin Zumo XT2 GPS?
OhBobH
I recently purchased a 2022 RT Ltd and am looking for any installation tips regarding the Garmin Zumo XT2, which is currently enroute. Any info on mounting hardware and wiring would be greatly appreciated. Thanks in advance.
Bob
I had one like this on my 2024 Spyder RT S2S with a Garmin Zumo XT GPS before CAN-AM got Apple CarPlay to work.
It is wired into the accessory power port to provide power for any GPS.
There's a link on the page to the installation instructions in Acrobat PDF format.
This is the XT mounted on my 2022 RTL handlebar and wired to accessory connection on right side Works great.
Jim
On my '22 RTL, I mounted it between the handlebars. I used the Lamonster F3 and 2020+ GPS Mount. I had to change the small mount bracket on the Lamonster Mount to the bracket included in the XT2 to allow for power connection to the back of the XT2. I dropped the power line to the accessory connection on the right as RealWing did. It was an easy install.
I also added the one from Slingmods.com as it also had provisions to mount my XM antenna. I am using an older 665 as it supports XM radio, but the installation is the same.
jdg
Lamonster LG-1086 Mount, Sling Mods Switched Accessory Power Harness, 2" Ram Mount Extension. Ram mount extension moves GPS into my line of site, directly beneath the instrument panel so I don't have to move my head to see the GPS. Don't forget a safety tether for the unit.
