any trikes with Auto tranny?
I was curious to know if there are other Trikes with full auto trannies besides Spyders..
And also not pay an arm and a leg for it.
The Spyder doesn't have a fully automated transmission. It's only semi automatic (big difference). The Ryker is fully automatic (CVT). I can't think of any other 3 wheelers that have a fully automatic transmission unless you start talking about Slingshots or a Vanderhall.
:agree: The SE trans on our Spyders are actually the same MANUAL transmissions the SM's have, only with some sexy & very fast computer/electronic shift controls & an oil/hydraulic clutch (SE6) or centrifugal clutch (SE5) :ohyea: In fact, if you look underneath the left hand side of your SE Spyder just inboard of your left foot, you can even see the shift lever shaft still sticking out the side of the box! ;)
So don't ever try to kid yourself that you've got an auto Spyder, and you really shouldn't try to drive it like you would an auto :lecturef_smilie: It's still a MANUAL gearbox & if you want to use it to its' best capability, then it needs you to initiate the changes, even if the computers do have a 'save your arse from dropping the revs/speed too low for that gear' downshift function built in! :rolleyes:
Well, the Ryker could be a candidate, but, a truly auto trike, set up with the same configuration as a Spyder (two up front/one rear wheel) other than some crazy Chinese knock off 250cc POS, you may be out of luck.
2018+ Gold Wing DCT with a trike kit?
Those DCT's aren't actually autos either; they are Dual Clutch Manual Transmissions with a computer/electronic Rider interface that controls the gear shifting, albeit with a 'simulated auto' shift feel - but it's still a Manual Gearbox, and many if not most of the DCT's out there still have a Manual Shift option as well as the 'simulated auto' interface. :thumbup:
The wording in red pretty much disqualifies most all road-legal trikes, except some small displacement trikes and a few scooter conversions.
The "Stallion" has a fully automatic transmission. I am not sure if they are made anymore, but it was an interesting looking vehicle. Has the same drivetrain as the 2000's model ford ranger pickup. 2.3 L 4 cyclinder.
The "Stallion is no longer made, however I think the Boss Hoss Trike has an auto trans with reverse
From the Boss Hoss website: https://bosshoss.com/about/ at the bottom of the page.
The Final Assembly Department is where it all comes together. The factory new General Motors engines and custom built proprietary 2-speed semi-automatic transmissions with reverse for the bikes, or in the case of the trikes a modified and remanufactured 4L70E 4-speed overdrive automatic transmission with reverse are mated together. After the union of the engine and transmission, the U.S. Patented Boss Hoss frame is wrapped around the drivetrain assembly by splitting the two piece designed frame. This allows the Boss Hoss to maintain a compact design, which contributes to the bikes amazing light feel off the stand and nimble cornering characteristics. Each unit is built on our multi-station assembly line that allows experienced assemblers to construct and document every stage of the assembly process. No Boss Hoss is complete without being test run to our quality and performance specs.
Quite the machines! But then they should be with a price tag in the range of $65,000 to $75,000! :yikes:
Boom trikes have models with full auto. As they are car engined you can get 'flappy paddle' versions which would be similar to the Spyder. We sometimes get together with the local group on rides, as you can see they are more traditional style trikes:
I drove a Vanderhall at D3WR. It was very exciting and a blast to drive. I found it hard to get in and out of and the cockpit was very crowded. At 6'ft 260 lbs I do take up a little extra room.
I have a 2021 Honda Gold Wing DCT. Pulling in a HD clutch with my arthritic hands was becoming impossible so I switched to the GW.
For me the DCT in Auto mode is a mixed bag. I LOVE it in heavy traffic but find it frustrating in the twisties where it tends to upshift in the middle of a bend. Riding in Sport mode helps but most of the time outside the city I use the paddle shifters. Similar to the Spyder the DCT will downshift automatically in even in manual mode if the revs drop.
The main reason I am considering a Spyder is the challenge of slow speed riding and U turns on a 800 pound bike without a clutch. There’s no ability to “ “feather” the throttle response and drag the rear brake in slow speed maneuvers. I am losing confidence which is not a good thing for a 72 year old on a large motorcycle.
I suspect there’s a Spyder RT in my near future......
