Anyone going back and forth from their Spyder to a motorcycle?
The only thing I would suggest is that when you first get the Spyder, do not ride the 2-wheeled stuff until you feel comfortable on the Spyder and you have built up the muscle memory for riding it. Basically, don't add confusion to your transition. Once you have that firmly under your belt, then the transition between the two will be much easier. The first five miles will probably always be a quick transition relearning curve.
jdg
