Anyone know where to get Accessory switches that look like OEM? - 22 RT-L
slhanks004
Hi,
I have a 2022 Spyder RT Limited and I am adding a set of driving lights. I would like to use a factory-looking switch in the console panel rather than drill a hole to mount the push button switch that came with the kit. I have a plug in the unused hole just to the right of the heated grips switch. The problem is, I have looked for and have been unable to find a rocker switch that fits in the hole.
Does anyone know a source for this switch? I know I could just buy another heated grip or seat switch, but ideally, I'd like it to be a running light switch. Surely someone has sourced a switch like this from somewhere?
In addition to those, you can find others by searching for Carling Contura. That's the brand and model of the switches. You can even find sellers that will print just about anything on the switch caps!
I used Carling L-series from Spemco.com; they seem to be an exact match to the factory. There is a large selection of types/styles and the Carling website has diagrams showing their function and how to wire them.
