Where do I find Switched Accessory Power on a 2026 Spyder RT LTD?
Islander2017
Hi All, looking for some advice to find a "switched" accessory power source for my Aoocci C6 Pro CarPlay screen (2026 RT LTD). I saw on line where someone use the accessory power connector to the left of the ECU (see photo). In the video I watched it was switched but mine had no power until I put in a fuse in the right fuse box in the empty slot (7). I have power but its all the time. Thoughts, suggestions? Thank you
Dustin
You say you had no power, did you start your spyder? Maybe by adding the fuse it powers that plug all the time and without the fuse it only has power when the motor is started. Turning the switch to start will not power the plug only when the motor is running will you have power. I read something about that somewhere. I think?
On the 24 RTL that plug goes hot when you turn on the key, start or no start. I have seen posts that stated that connector on the 25 is on the other side of the bike but I have not verified it.
