Anyone touring on a Ryker?? Experiences?
I've been looking at the Can-Am Ryker 3 Piece Saddlebag & Top Case Luggage System by Spyder Extras.
It provides 93L of capacity and they can all be locked. Each piece can also be easily removed to take into the hotel.
Do you have any specific recommendations?
That'd be a super nice outfit, Gael. Don't think you can do any better.
Sarah
I have a 2024 RT Limited, rode about 500 miles in one trip, and got tired of stopping for fuel. The ride was great with my driver's backrest. I couldn't imagine stopping for fuel for several thousands of miles.
I didn't track my mileage to any great extent. High speeds and head winds are killers, I got 27 mpg in S. Dakota. But much, much better on slower roads, I got 192 miles on a tank up in BC.
Yep, factory Kendas on the front, and a 205/45R16 on the rear. The tires did great as far as I'm concerned. I'm so glad I changed out the rear, the factory Kenda felt pitifully flimsy compared to the Hankook. Now that I've been there, I'd never pit the rear Kenda against the conditions I encountered on the Dempster Highway.
Over the years we've pared down our tool kit and pretty well figured out the essentials, so I didn't tote any dead weight. I kept wishing I had a compact scissor jack in the duffle, just in case. I may try to hunt something up.
Sarah
Thanks for sharing your ride experiences. I have been pondering the idea of a jack solution. I have settled on a small “air wedge” inflatable bladder. The one I selected has a 500 pound capacity and a 3” lift. Two only weigh a few ounces, combine for a six inch lift, and deflate flat. I figure I can find rocks or wood to fill the gap between frame and ground. Once I get the wheel off the ground I could brace it with more rocks or wood. In a pinch, I could pull a wheel and/or repair a flat. Not perfect, but a low cost, compact solution.
Never knew such a thing existed, thank you!
Sarah
And as I had an ideal opportunity to demonstrate just this arvo, they also work REALLY WELL to 'ease' the top a car window open juust enough to squeeze in the necessary to unlock said door!! (y)
They're thin enough to slide into a pretty small gap, but pump up wide enough and gently enough to ease the top of the window glass clear of the frame so that you can reach in to flick/pull the door lock release. And I can see that a couple stacked together would make a small and easily stowable jack suitable for all sorts of things - and it's a good thing I've got a few of them stashed in the frunk already! ;)
I’ve been following the thread because I intend on doing a little touring with my ’22 Sport this year. Took a few short trips last year, but planning on several longer ones during the coming months.
Fortunately, my Sport came with the SE three-piece luggage set, and the Ultimate seat w/backrest. I replaced the latter with a Show Chrome Combat Solo Seat (and a back rest) so I would have enough room to add a 2 gal. Rotopax aux fuel container. I recently added a Kemimoto Adventure Windshield. In its lowest position it's as tall as a stock shield when fully raised. It's also several inches wider, and obviously considerably higher in the full raised position.
Tools include a wheel nut socket, 1/2” to 3/4” adapter, tire plug kit, combo air compressor/jump start system, bottle of Slime, and a few misc. hand tools. All those go in the frunk. A more complete tool roll fits nicely in the SE tail trunk and really doesn't take up all that much room.
I too will be looking for a smallish scissors jack, but in the interim those air wedges have piqued my interest. Too bad they don’t have fittings that would accept a compressor’s air chuck.
Needless to say, I’m ready and looking forward to the upcoming riding season.
No need for an air compressor. Each air bag has a small bulb attached to inflate the bladder. Maybe a dozen pumps and the bladder is inflated.
