WRCLVR
If anyone is using Erickson e-track tiedown straps with Erickson e-track wheel chocks, (or Macs, which is similar). I would like to find out the following so I can make an informed purchase:
1. Are you using just the straps or wheel nets?
2. How easy is it to fit the straps if using them (this is for the 2" wide straps)
4. If using the wheel chocks, are you using one or two per wheel?
5. Is the standard strap strength working ok, or do I need to jump up to ~2000 lb straps (each)?
I have a new 2025 24 ft dual axle enclosed trailer with 3 runs of e-track fitted to the S2S track width and going the full length of the trailer. 10000 lb GVWR with electric brakes and surge backup, pulled by a 2017 Ram 3500 CTD dually. The trailer weighs 4400 lb and will weigh ~6600lb loaded with both S2S's.
A.) over the front wheels?
B.) over the rear wheel
3. How easy is it to fit the wheel nets if using them (IIRC those are 2" webs as well )? Fronts and rears?4. If using the wheel chocks, are you using one or two per wheel?
