Bike-O-Din
I have a 2011 RTS. I have had the tire changed, and the tech did not do a good job of aligning the belt. I have the wrenches and sockets and have done the belt tension and alignment. A bit tricky, but not impossible. However..........
I want to torque the axle to the 96 flb spec, but there is not a tool that I can find that will allow the torque wrench and the socket between the exhaust and the axle to torque it on the nut side. I even found a shallow/low-profile socket that is for oil filters, but it does not come with a 1/2 drive, and if you put the extension/converter on the wrench, the combination is bigger than just the regular 1/2 drive 36mm socket. I looked at several videos on YouTube, but no one addresses how to do the torque!!? In fact, it looks like most people just tighten it so it "feels" right.
I have read several posts here about the need to get an even bigger wrench for the later years that expect to use the 166 flb setting - I cannot even begin to believe that you could fit something even bigger in that space.
Is is OK to torque from the bolt (left) side instead?? That would make it a piece of cake, so that is what I did, but I want to know if there is another way.
Thanks to all in advance for the advise.
Bill
Bill
