propbuildervash
Hello Spyder folks,
Had a question that I'm posting to all Spyder folks running a Noco NLP20.
1. Do all spyders run the same battery mounting bracket as a 2019 RTL?
2. How did you mount the battery? Any issues with lateral movement of the battery using the foam shims?
3. Do you find the mounting bracket to battery interface lacking?
I just picked up a Noco NLP20 and got it charged up. I personally am not loving the mount or the foam insert between the bracket and the battery.
Would there be any interest in a 3D printed battery locking bracket to more securely hold the battery and works with the OEM bracket without modifications?
Jeff
Jeff
